Tapered Cutaway with Fox-Bender?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=1376
Author:  Harald Lane [ Thu Mar 17, 2005 7:34 pm ]
Hello everyone! I?m looking for info on bending a tapered Cutaway ala Cumpiano with the Fox-Bender. Have already made normal Cutaways for Archtops,but have concerns about bending sides with different radii on the Bendingform.
After doing one tapered Cutaway on the Hotpipe, there must be something simpler.... .
Author:  Dickey [ Fri Mar 18, 2005 1:17 am ]
Harald, what is a tapered cutaway? Pointy or rounded?
Author:  Mattia Valente [ Fri Mar 18, 2005 3:03 am ]
I *think* he means a compound radius cutaway. As in, if you've got a tapered heel, the part of the side with the cutaway follows the taper, and isn't perpendicular to the top and back. Basically, the cutaway becomes a rather more conic section of some kind, rather than a cylindrical one.
Author:  Dickey [ Fri Mar 18, 2005 4:13 am ]
Ah yes, Charles Fox is doing this, looks great too.
Author:  Wade Sylvester [ Fri Mar 18, 2005 4:53 am ]
Harald,
You could bend in the odd angle with a pipe after you have completed the other bends with the Fox bender. Since you have to make a block that conforms to the angle anyway, you could use the block to hold the angle as it cools and dries after you ballpark it on the pipe.
I do hope this is what you guys are talking about?
Author:  Dickey [ Fri Mar 18, 2005 7:03 am ]
Whoa-ho! Wade, ya been holdin' out on us Mamma-miya what a beauty!
Author:  Pwoolson [ Fri Mar 18, 2005 7:54 am ]
I always touch mine up on a pipe. I tried to come up with a way to make the bender do it but alas I couldn't. Charles touches his up on a pipe as well so my guess is that there is no way to do it on the bender or he would have found it.
Author:  Pwoolson [ Fri Mar 18, 2005 8:46 am ]
Author:  Darin Spayd [ Fri Mar 18, 2005 9:25 am ]
What ever happened to "Where there's a will, there's a way"?!
Author:  EricKeller [ Fri Mar 18, 2005 11:42 am ]
I haven't done it, but I was thinking about this kind of cutaway, so maybe I'll try. I would angle the plunger itself and keep the slats under tension.
When factories (furniture, etc) bend wood, they have a way of keeping the wood under tension. That's one thing that the Fox bender doesn't do very well.
Author:  Darin Spayd [ Fri Mar 18, 2005 3:33 pm ]
Eric, check out the method that John Hall implements. (Bluescreek Guitars) I believe his bender holds the ends after a partial waist bend. Once the ends are secure, the waist caul is fully clamped.
Author:  Harald Lane [ Fri Mar 18, 2005 8:08 pm ]
Thanks all for your replies. It seems that I have no other choice for bending on the hotpipe. After a discussion with some violin makers, one came up with the idea to bend an normal Cutaway and then change the radius on the hotpipe. Thats the way he does when building a Viola da Gamba.
Wade: Great looking work!
Again thanks all. Harald
